Hackaday.io Hackaday.io
Sign up Log in
Commercial home automation
Home automation using the Loxone series of home automation products along with hacks to extend functionality and reduce cost
ian-nortonIan Norton
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
15.5k views
1 comments
11.1k followers
  • Description
  • Details
  • Files 0
  • Components 10
    • View all
  • Logs 8
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
15.5k
1
11.1k
23
Team (1)
  • ian-nortonIan Norton
Join this project's team
MISC
ongoing project
home automation
Related lists
Raspberry Pi Projects
Projects based on everyone's favorite low cost Linux Machine - The Raspberry Pi
DIY SCADA / smart home
A list for all DIY smart home projects
This project was created on 03/21/2015 and last updated 2 個月前.
Description
Components
  • 1 × Loxone Miniserver
  • 2 × Loxone Extension
  • 1 × Raspberry Pi
  • 1 × BH1750FVI Digital Light intensity Sensor Module E-bay
  • 1 × Basic SPDT Relay Carrier with 5VDC Relay Pololu 5v relay module from Cool Components
View all 10 components
Project Logs
Collapse
  • Presence sensors again!
    Ian Norton • 02/28/2017 at 21:59 • 0 comments
    That nice man Malc Crook (https://hackaday.io/mal8837) contacted me after my last post on this (https://lamm.space/2016/09/10/presence-sensors-revisited/) to say he'd bought some sensors from the same supplier and they were different yet again.
    Malc sent me some sensors to hack and return to him so I've added a new post at https://lamm.space/2017/02/28/presence-sensors-again/ with details.
    Hopefully this will help some people!
    Ian.
  • Presence sensors revisited
    Ian Norton • 09/10/2016 at 18:45 • 0 comments
    In a previous post I talked about 24v presence sensors for Loxone home automation:
    https://hackaday.io/project/4857/log/16523-is-there-anybody-there-click-once-for-yes
    Shout out to Malc Crook (https://hackaday.io/mal8837) and Adam (https://hackaday.io/Bobbsta10) who both contacted me to say that the PIR linked to in the original post is no longer the one you get when you order the same item from the same seller.
    Fear not, for I have hacked the new one this evening and it’s pretty straight forward.
  • Squeezing a quart into a pint pot
    Ian Norton • 07/12/2015 at 15:36 • 0 comments
    So you've used up your eight digital outputs on lighting circuits but you've got another two to add, what do you do now?!
  • What shall we wrap it all up in?
    Ian Norton • 06/04/2015 at 21:44 • 2 comments
    Any enclosure needs to be easy to access yet provide enough space to get all of our cables in and out without being too big. A tough challenge!
  • Is there anybody there? Click once for yes!
    Ian Norton • 04/14/2015 at 20:01 • 10 comments
    So following on from my previous post about switches at https://hackaday.io/project/4857-commercial-home-automation/log/16130-switches-are-simple-right let's talk about Passive Infra Red (PIR) sensors.
  • Switches are simple, right?
    Ian Norton • 04/05/2015 at 21:01 • 2 comments
    Okay, I'm editing this as my first attempt has been badly mangled somehow. Starting to regret using hackaday.io for this, seriously guys is there no markdown or something I can use with copy and paste from somewhere else or a preview option?!
    Switches are simple right? You'd think so but when talking about home automation, not so much. Trying to find a UK back box switch of the right kind turned out to be harder than I thought...
  • The software only runs on Windows?!
    Ian Norton • 03/28/2015 at 17:56 • 0 comments
    So from my previous post, you might gather I'm a GNU Linux Open Source toting hippie socialist type. You'd be right :)
    So I bought hardware who's configuration software only works on Windows. It also runs under Wine with some caveats.
  • Which solution to choose?
    Ian Norton • 03/21/2015 at 09:58 • 0 comments
    When I decided to embark on a home automation project, I spoke to a few people, read some websites and did some thinking. You might well expect that for a project that is a substantial financial outlay and a commitment to an eco system that will be with you for a long time.
View all 8 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
clarkesmith392 wrote 06/02/2023 at 19:14 • point
Thanks for sharing it. I will definitely use these products in my custom smart home by https://www.newdayconstruction.co/custom-homes
Hackaday Prize 2019
Raspberry PI based, fully modular PLC for home and industrial automation.
Project Owner Contributor
IOTON MICRIO
andrey-vAndrey V
Smart dimmer for 0-10v lights without needing 4+ devices on wifi
Custom ESP8266 4 channel 0-10 dimmer
brandonbrandon
Ground station deck to control (some of) them
ESC.VTOR
mkdxdxmkdxdx
Official Hackaday Prize Entry
Reef tank controller used to monitor various parameters such as temp and pH, and also control equipment such as pump and lights.
AquaPic - Aquarium Controller
skyler-brandtSkyler Brandt
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Commercial home automation", please tell us the reason.
Send message
Remove Member
