The board is for sale on Lectronz!
All Features:
- USB-C PD3.1 EPR Power Delivery Sink
- Selector switch S1 for 5 V, 12 V, 20 V or 28 V (9 V or 15 V with solder mods)
- Selector switch S2 for 1 A, 2 A, 3 A, or 5 A ( 2.5 A or 4 A with solder mods) for –FA01
- Max current 5 A
- Red LED to indicate status as, power on, voltage or current mismatch, abnormal connector impedance, fault conditions
- Snap off option for mounting tabs
- For fixed voltage and current, the switch could be replaced by solder jumper
- Small form factor to be heat shrinked as part of the power cable
- Size 53 mm x 15 mm (without breakoff tabs, 30 mm wide tabs included)
- Height 12mm with screw terminal and switch, 6mm without.
- Lead free assembly
This is a set and forget device. Set your current and voltage needs before plugging the device to your USB-PD source and enjoy the power at the output. This is not a power supply to change voltage and current during operation.
MagicWolfi
Vq1q2: voltage across both FETs
V_J2 : Voltage at output connector on the PCB
