BU03-Kit Development Board (Hardware Section 1)
——AndyL
1. Hardware Overview
1.1 About BU03-Kit
The BU03-Kit is a UWB development board based on the BU03 (DW3000) module and powered by an STM32F103C8T6 MCU. The BU03 module integrates an onboard antenna, RF circuitry, and power management.
It supports Two-Way Ranging (TWR) and Time Difference of Arrival (TDOA) positioning with up to 10 cm accuracy and a maximum data rate of 6.8 Mbps. Applications include IoT, mobile devices, wearables, and smart home solutions.
1.2 Key Features of BU03
- SMD-40 pin package
- Compliant with IEEE 802.15.4-2015 UWB and 802.15.4z (BPRF mode) standards
- Supports channels 5 and 9
- Integrated MAC layer for extended communication range
- Data rates: 850 Kbps and 6.8 Mbps
- Supports TWR, TDOA, and PDOA positioning
- 10 cm positioning accuracy
- High tag density support
- Integrated hardware AES 256 encryption
- SPI interface and 9 configurable GPIOs
- Programmable transmit power
- Sleep mode current <1 µA, ideal for coin cell battery solutions
- High-precision positioning
- Strong security
- Low interference with other communication technologies
- Low power consumption
Typical Power Consumption (@3.3V, 25°C):
Mode | Average Current (mA) |
CH5 TX @ 0.85 Mbps | 17.03 |
CH5 TX @ 6.8 Mbps | 15.06 |
CH9 TX @ 0.85 Mbps | 24.85 |
CH9 TX @ 6.8 Mbps | 22.6 |
CH5 RX @ 0.85 Mbps | 39.81 |
CH5 RX @ 6.8 Mbps | 40.01 |
CH9 RX @ 0.85 Mbps | 49.23 |
CH9 RX @ 6.8 Mbps | 48.05 |
Instantaneous Startup Current | 174 mA |
Deep Sleep Current | 179 nA |
1.3 Pin Definitions
Pin | Name | Description |
1 | EXTON | External device enable during wake-up; used to minimize power consumption. |
2 | WAKEUP | Brings DW3000 from sleep/deep sleep to active mode. Tie to GND if unused. |
3 | RSTN | Reset pin, active low; equivalent to power cycle reset. |
4 | IO7 | GPIO7 / SYNC input; reconfigurable if SYNC not used. |
5 | VDD | Power input (1.8V–3.6V), ≥200mA recommended. |
6-7 | VCC | Power input (2.5V–3.6V), ≥200mA recommended. |
8 | GND | Ground. |
9 | IO6 | GPIO6 / SPIPHA / EXTRXE; SPI phase select or external RX enable. |
10 | IO5 | GPIO5 / SPIPOL / EXTTXE; SPI polarity select or external TX enable. |
11 | IO4 | GPIO4 / EXTPA; external power amplifier enable. |
12 | IO3 | GPIO3 / TXLED; drive LED after transmission. |
13 | IO2 | GPIO2 / RXLED; drive LED during reception. |
14 | IO1 | GPIO1 / SFDLED; LED indicator when SFD (start frame delimiter) is detected. |
15 | IO0 | GPIO0 / RXOKLED; LED indicator for successful frame reception. |
16 | GND | Ground. |
17 | CSN | SPI chip select (SPICSn); also used for waking from sleep modes. |
18 | MOSI | SPI data input. |
19 | MISO | SPI data output. |
20 | CLK | SPI clock input. |
21 | NC | Not connected. |
22 | IRQ | GPIO8 / IRQ output; active high by default; reconfigurable. |
23 | NC | Not connected. |
24 | GND | Ground. |
Note : All GPIOs except SPICSn have internal pull-down resistors. SPICSn has an internal pull-up for safe operation when un-driven. Resistance varies with VDD (10kΩ at 1.8V to 30kΩ).
2. About the BU03 Module
The BU03 is an ultra-wideband (UWB) module based on Decawave’s DW3000 chip.
2.1 What is UWB?
Ultra-Wideband (UWB) is a wireless technology that transmits data via very short pulses instead of traditional carriers. The shorter the pulse in the time domain, the wider its bandwidth in the frequency domain — often reaching GHz levels.
Key advantages of UWB:
UWB systems typically follow the IEEE 802.15.4z standard, using Impulse Radio techniques.
2.2 UWB Positioning Methods
Distance-based methods:
- TOA (Time of Arrival): Measures the signal’s travel time to compute distance; requires synchronization among devices.
- TWR (Two-Way Ranging):
- SS-TWR (Single-Sided): One device measures the round-trip time; requires clock sync.
- DS-TWR (Double-Sided): Both devices measure and exchange timing information; compensates...
Ai-Thinker
