Fundrill
Using an affordable CNC to drill circuit boards
This is a small piece of python code that assists in drilling PCBs. Fundrill aligns the physical PCB with locations in a .drl file and verifies the data. Afterwards it produces gcode files which can be fed into a gcode sender for the actual drilling. More is visible on the youTube video https://www.youtube.com/watch?v=6cKb-Il8YiU In order to verify the location of the drill holes I take advantage of openCV. Once the camera sees the hole it can calculate how far off it is from its correct location. Thus in the verification it corrects any anomalies making sure the holes are perfectly drilled.
  • 1 × 1610 CNC Machine Low cost CNC machine e.g. 3018, 2418, 1610
  • 1 × USB Microscope
  • 1 × 3D Printed Microscope to Spindle Adapter
  • 1 × Small MDF Tile This will protect the CNC bed from drill damage
  • 1 × Drill Bits Preferebly tungsten carbide, with 3.175mm shank to fit the spindle
