Fidget cube
a fidget cube for kids that struggle with ADHD, it will be designed so it wont distract the teacher or others around.
0 followers
Small 10x10x10 cube that has been created to be quiet and entertaining without distracting others. the cube consists of 6 sides and is designed to calm people with sensory disabilities down such as autism and ADHD.
button code.py
code for all of the buttons on fidget cube. Comments explain details on editing code.
py - 1.55 kB - 04/28/2025 at 17:28
Download
  • 3 × Slide Pots https://www.amazon.com/HiLetgo-Logarithmic-Potentiometer-Arduino-Electronic/dp/B01CZVZ16O/ref=sr_1_4?crid=10IDAVEB9ECCV&dib=eyJ2IjoiMSJ9.0DNYaDCko4HS-yumF0wWZ58cCUrWsbRKVD7XqIWirpmQHTqhQ6FiOCYZ5K6TGqgwq-d2cqlD5fjF2AtvHmkONpHnHVXtC3QhLGHC1mNEiUYG6MRzgYwVxV2y7kPdc6BapGsrG4z0BvY1UonsuYYN2VgRj4iCa6emTq_PgHVRipthGry2mQJ5P9A65RgZ7F6Q85oiXcwZoA2ieCFy7QXI9q_GTh_o__2rMfGn9Z4MaynTWkDP0d6VA6yLDyNlMij_q_wQxpK87Mhp-fO-LTiAzVa5pC23ydPfqfiP0f0eSyE.7AnkrfkHDHBBq2FwA-dYvl1JiWQFbljeRfO3LALdZzQ&dib_tag=se&keywords=slide+pot&qid=1745601906&sprefix=slide+po%2Caps%2C173&sr=8-4
  • 2 × led arcade buttons with 12c https://www.amazon.com/EG-STARTS-Arcade-Buttons-Multicade/dp/B01M0XPWGG/ref=sr_1_1?crid=11KHM3CZ1H9I9&dib=eyJ2IjoiMSJ9.Ah-Ccs7zBW95CcnNG7k6qIXhLplnRyAEX4bqYlIXZ6EYDPbbe5MZ0lgr_0weChyCZiMw1FF6zNSQk986offiEhvgk_2KMDVtC-CX6wr1dRBkiHSGbOYLB2J0pK4x-eCo5LnOcGQ1yj_5fcuMPamRfA1_hYAdAiHndca0Bm4Mzqw6QYE3Th_4Ff_hI3U0F_ypPOAcXcAJoxJqsE5dWZ3c_4JBvUiMEkjOnX5ndTRo9wA.mpEWqJWoxsyeHidWFCn0MD8CAf8aUD5th16OOXMl8u0&dib_tag=se&keywords=12c+arcade+button&qid=1745601983&sprefix=12c+arcade+button%2Caps%2C198&sr=8-1
  • 1 × 24 bit color 64 rgb leds https://www.robotshop.com/products/rgb-8x8-64-i2c-24-bit-color-programmable-led-matrix-panel-raspberry-pi
  • 1 × ada fruit feather https://www.adafruit.com/product/4884
  • log
    bensons04/10/2025 at 17:42 0 comments
    1st week: Created led lights w lights pulsing, designing wall for cube, settled on a design. Set backs we faced included, issues w connecting circuit and tinkercad dimensions, also Hackaday website is down.
    2nd week: focused on the prototype and making the dif walls of the cube, finalized details and began working on making other sides, my j key broke, hackaday fixed and log will be transfered, hackaday still a little shakey,
    New boost
    3rd week: we worked on the design and finalized it, out group finished the walls in tinkercad. We took pictures of our project and added them all in Hackaday.
    Week 4: major design changes, we switched from python to c++,  as well as changing our light system.
    Week 5: Started using a new board, worked on connecting an 8x8 neo pixel wall, we also added screw holes to our wall design. We also faced some wiring issues, and we posses a bread board now.
    Week 6: Started 3d printing the walls. Managed to get the light isplay to light up, we struggled to connect the slide pot to the 8x8 neo pixel pallet.
    Add a comment here…
View project log
  • 1
    Download cube wall files
    Files are accessible in files on Hackaday and all components are able to be bought on links for materials list.
  • 2
    3d print the walls
    Using a 3d printer, assemble using 3.1 mm screw (make sure they fit tightly together)
  • 3
    install electronics
    Take circuit board, connect all the wires to correct locations (see pictures for detail)
View all 3 instructions
