SilentELWireInterver_Datasheet.pdf
Simple Datasheet with Wiring Diagram
Adobe Portable Document Format -
959.62 kB -
09/30/2019 at 03:40
Preview
QUIET_EL_POW.pdf
Current Schematic for the Design.
50.38 kB -
09/07/2019 at 04:22
Preview
Quiet_EL_BOM.csv
Detailed BOM.
Comma-Separated Values -
1.03 kB -
09/07/2019 at 04:20
Download
These two ghosts are powered by this circuit. They have about 28-33nF of cable in each. They ran about 290-300Vpp, instead of the full 360Vpp. I lowered frequency to 1kHz to help voltage.
JPEG Image -
244.13 kB -
11/02/2018 at 03:09
Preview
The moon is powered by this circuit, the rocket and spider web are powered on off the shelf inverters. The rocket runs are full brightness, and 2kHz.
JPEG Image -
133.73 kB -
11/02/2018 at 03:09
Preview
ASSEMBLY.asm
This code is not optimized for any particular inductor mosfet pair. It does control the voltage well, just needs to be optimization.
asm -
558.00 bytes -
10/14/2018 at 02:18
Download
EL_POW_USB_POW_SCH.pdf
Here is the schematic. The best inductor and MOSFET choice has not determined. There is a very simple assembly code frame work attached as well. The code, inductor & MOSFET are all related, and must be optimized. But the code was very simple to change.
48.74 kB -
10/14/2018 at 02:01
Preview
QuietVsNoisy1.mp4
Video of a AA battery EL inverter next to the quiet one. i don't know the brand of the batter powered one, I know it is very common. I took the video on my phone, the picture are not awesome but it does show the difference in noise level.
MPEG-4 Video -
44.67 MB -
10/13/2018 at 02:30
Download
