Hackaday.io Hackaday.io
Sign up Log in
VALTALK V1
GSM based Relay control board using DTMF/MQTT with IVRS
raviypujarraviypujar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
View Gallery
Public Chat
403
0
1
2
Team (1)
  • raviypujarraviypujar
Join this project's team
  • Designing a DTMF based Home automation system - GS
hardware
ongoing project
DTMF GSM 2018hackadayprize sim800c IVRS
Related lists
111
111
This project is submitted for
  • Robotics Module Challenge
This project was created on 04/26/2018 and last updated 8 years ago.
Description
It had been a long time since i wanted to make a building automation system. In fact it was the first product i ever dream&#x2019;t of making. Time passed and i didn&#x2019;t quite find the time and interest to venture into it as i felt that building automation is a old concept and there are too many players doing the same stuff.<br><br>So i designed this board, which can control the relays on board, based on the inputs provided either from cloud or from a call using DTMF.<br><br>Features :<br>For the first iteration we designed it to have the following features,<br><br>4 cube Relays driven by MOSFET&#x2019;s to control 110V to 230V AC appliances<br>SIM800C 2G Quadband GSM module for cloud/call connectivity with micro SIM card connector<br>External Whip Antenna with right angle SMA connector<br>MP3 player with micro SD card<br>STM32 Cortex M0 Low power MCU with RTC<br>Switching power supply to take inputs from 5V to 24V DC<br>DC power jack for power input<br>SWD connector for programmi
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A UPS modified such that power ports are individually controllable, via wireless RF network commands
Project Owner Contributor
Reactron energizer: Interruptible Power Supply
kenji-larsenKenji Larsen
This board is responsible for controlling the thrusters of our newest AUV.
Thruster Board
ufrj-nautilusUFRJ-Nautilus
The 2017 Hackaday Prize
Plugs into the fuse socket of mediocre switch boards, connects it to WiFi and monitors the power consumption of that room through smartphone
AutoFuse: Plug and Use Automation & power monitor
animesh-chattopadhyayAnimesh Chattopadhyay
Raspberry Pi Expansion Board / Multi-purpose Access/IO w CM socket
The AccessHAT
ronRon
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "VALTALK V1", please tell us the reason.
Send message
Remove Member
