Code
A project log for Solid-state garduino with RTC & LCD!
Garduino Enclosure with Solid State Controlled Relays, Real Time Clock, and status LCD.
vwphanvwphan • 02/25/2014 at 14:51•0 Comments
I've been struggling through the code.  I got it all working finally. It's not perfect, but when theres a fault, it fault's to a safe state.  The fault doesn't run as perfectly as I'd like, but that's ok.​
